ā03-13-2009 08:39 AM
ā03-13-2009 09:53 AM - edited ā03-13-2009 09:54 AM
ā03-16-2009 02:02 AM - edited ā03-16-2009 02:05 AM
ā03-16-2009
03:03 AM
- last edited on
ā10-29-2025
09:28 AM
by
Content Cleaner
Hi Gareth1983
You are on the right track. But I think you need some better understanding of the DFT concept. This and http://zone.ni.com/devzone/cda/tut/p/id/4278, and this https://www.ni.com/en/shop/labview/using-fast-fourier-transforms-and-power-spectra-in-labview.html will help you out. Remember that in newer labview versions the DFT output is a complex array. In older versions the output was split in a IM and RE part. But you will find the functions you need in the complex palette
good luck with your school assignment
ā03-16-2009 03:31 AM
