display acquired data
Hi
I have been able to acquire data using my Vi but would like to display the acquired data ( text file). When i used the example- display acquired data (scaled) VI, i get an error - not enough memory. I am not sure whether the data in the file is too big or what is the problem. Can any one tell me about it.
The data i have has two columns, each with about 45k rows of data. How else can i display it ? Pls help me out!!!
Thanks for you help in advance.
Regards
Krithika
(3,122 Views)
Could you send your program ?
greetings from the Netherlands
(3,095 Views)
Krithika,
How did you write to this file in the first place??
did u use the example vi, 'cont acq to file(scaled).vi"??
coz the example VI you have mentioned is designed to read from this VI.
(3,077 Views)
