display array in table
I manage to generate a 6x10 matrix array and I wanted to display it in a table. Is there a way to do that? I tried using a multi-column list box but an error comes up saying that the arrays do not match. Is there a way to fix this/ another way of doing it?
Thank you
(4,450 Views)
Format the matrix into a 2D Array of strings.  You can then put that straight into a table indicator.
(4,448 Views)
Thank you for your reply. How would the array be converted to a 2D array?
(4,442 Views)
this could be one way how to do it.
Duri
(4,417 Views)
