display custom time-stamps on a graph
Hello
I have some data in the format (yyyy-mm-dd, value). I would like to plot it like that in a graph chart.
The problem is that I cant transform the string 'yyyy-mm-dd' into a labview time-stamp.
Is there any way around?
Antonio
(2,442 Views)
Use Scan From String function:
Note that you did not provide time information, so you just get 6 PM. Check the LabVIEW Help for further details on the Scan From String function.
Message Edited by smercurio_fc on 05-22-2008 01:58 PM
(2,437 Views)
