display every 5th element of the array
Great, glad my solution worked.  Please mark this as the solution and give Kudos if you feel this was helpful.
If the value of any multiple of 5 element is unwanted (i.e. 0.000) you will have to perform a check on the value as well.  Of course if the value is not exactly zero you will need to consider a range to check for.  There is an function "In Range and Coerce" that will allow you to set upper and lower limits, and outputs a boolean if teh input value is within the specified range limits.  This may be helpful.
Dan
Message 11 of 12
(543 Views)
Sure thing.
Message 12 of 12
(539 Views)
