display in black & white mode
I need to display my IHM in black & white mode.
Is there a property node or something to do this??
James
(3,058 Views)
Hi James,
IHM = HMI = Frontpanel?
Well, you could use the brush tool to paint all in black and white. And it helps to use only classic controls/indicators...
(3,044 Views)
Hi GerdW,
Yes, I would like to say frontpanel (IHM in french 😉 ).
The thing is that I have to be able to change dynamically from/to color mode to/from black & white (or greyscale).
In worth case, I can effectively use property node to color each control and indicator but what a mess...  Moreover, I usually use system controls which I think can't be colored.
So you don't know any way to do this? even using Windows SDK/APi?
best regards,
James
(3,034 Views)
Would this example help?  It has some big caveats but might help with what you are trying to do.
Alex Person
NI-RIO Product Support Engineer
(3,021 Views)
I can't open it because I'm running 8.6.1f1.
Can you please compiled it in 8.6 compatibility.
best regards,
James
(3,019 Views)
It will take a minute to post but I added an 8.6 version to the downloads section of the document I linked to.
Alex Person
(3,013 Views)
