display of spectrum of data on graph
I am sending serial data from Arduino (baud rate 9600) to the Lab view. These data are to be displayed on form of bar graph. Means if i send 10 numbers of data 1,2,3,4,5,6,7,8,9,10 then it will displayed on x-axis position of 1,2,3,4,5,6,7,8,9,10.
Now I am changing values to 10,20,30,40,50,60,70,80,90,100 then it will be updated on x-axis position of 1,2,3,4,5,6,7,8,9,10.
I am confused how can I achieve this. Please help me to do this.
(2,873 Views)
(2,867 Views)
Thanks for your prompt reply...
can you share .vi to receive data on com port and display on bar chart...
(2,863 Views)
Accepted by topic author nikhilgujar87
What is your question? how to get data, or how to draw a bar graph?
I answered the second question.
You just need to send the array to the graph. The rest is done in the settings, as in the image.
I do not know how to get the data, because I do not know how you send it.
To work with the com-port you will need VISA. See the examples, everything is simple.
(2,842 Views)
