display one column in a list from a table in sql database
@mfaizolmi wrote:
Hi Logan,
Thanks for the suggestion...
what i need is only one column to be displayed inside a list which will be used as a control... Below is the list box i wanted... the displayed items are the in the same column... i tried your method, but it can only display the first item "kebab"..... but the interface of the one you suggest is not like in the image attahced...
i did try the sql-style query, but nthing change..... anyway, what do you mean by the sql-style query? do i need to use "EXECUTE" block...?
But you do get a result? What if you drop an array indicator and show the result, could it be the resulting array needs transposing?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 13
(922 Views)
Are you sure that the select statement is correct?
Message 12 of 13
(918 Views)
Hi all,
thanks for all of your kind reply and help. i already found the solution for my problem and with this reply, i attached the image of my solution...
the solution i was looking for is in the file "block diagram for list box", while the other one is my test vi for this solution...
thanks for your help...!!Smiley Happy
Message 13 of 13
(892 Views)
