display strings on x axis on graph
hi
I need a graph with 2 axis, on X axis I need display array of text and on Y axsi I have array of string or array of numrics (can I have both).
how can i connect my data to graph?
Message 1 of 10
(8,350 Views)
A graph can only plot numerical data, how else would you know how to graphically represent the data on a cartesian plane?
But I think you can replace the axis labels with custom text. So, if you use numerics for your data and replace the axis labels with the text then you might get what you want.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 2 of 10
(8,339 Views)
Nope. Apparently my hunch was wrong, you can't use string markers. But there are other proposed solutions:
https://forums.ni.com/t5/LabVIEW/Change-the-x-axis-scale-markers-in-a-waveform-graph/m-p/957294/high...
Message 3 of 10
(8,331 Views)
thanks for your reply
My X axis data is special time format that I save in SQL database and I read my data from database in string mode like this (1995/05/12 12:45:13) Now I need display this data on X axis.
Now I try your solution I hop it work.
Message 4 of 10
(8,306 Views)
Another reason to support this idea. 🙂
Message 5 of 10
(8,304 Views)
Accepted by topic author meysam_b
Hi meysam,
why do you think you need string markers on your X axis?
All you need to do is converting those database information into LabVIEW timestamps:
and format your X axis to show time…
Message 6 of 10
(8,281 Views)
Hi GerdW,
thank you very much for your good solution,
It is nice and worked!
Message 7 of 10
(8,268 Views)
Yes, you didn't say your x axis was a timestamp! As Gerd has shown, you can display time in the x axis natively, you just need to interpret your SQL format.
Message 8 of 10
(8,255 Views)
Hi Thoric,
I do have the same issue, but in my case are real strings and not dates.
I have seen this post here: Re: Is there a way to make table entries vertical rather than horizontal? - NI Community
But it is quite old and not very elegant and flexible.
Do you know whether in the last years something better came up?
Thank you
Message 9 of 10
(3,727 Views)
Hi logatto,
I am sorry but I'm not aware of any improvements to axes in this regard.
Message 10 of 10
(3,717 Views)
