displayin two msges on a single indicator
hi all
i have two massages
msg 1
msg 2
i want to first display the msg 1 on the txt indicator... then after a 3 sec delay dispaly another msg on the same txt indicator.
attched is a vi
Regards
(3,179 Views)
Accepted by topic author nolsqn
Write one string to the terminal of the string indicator.  The other string to a local variable of the string indicator.
Message Edited by Ravens Fan on 01-11-2010 12:25 AM
(3,176 Views)
Try something like this:
Message Edited by altenbach on 01-10-2010 09:29 PM
(3,173 Views)
How to Append below the First Line?..
I want to Display Multiple Message one after one in different time or in another stack sequence. in same string indicator. Is this possibel??
(2,838 Views)
Hi Anilgk,
I am not sure if I understand your question, but if you would like to combine two strings, you can use the concatenate string function.  Here is a screen shot of what your block diagram would look like and the output you would expect.
I hope this helps!
Kim W.
(2,817 Views)
Hello Kim
You are showing concatenate string function . But I want Continous text stream display in string indicator. I got the Answer for one of the Application Engineer from NI.
Thank you
(2,805 Views)
