Hi ,
Basically what iam trying to do is have mutiple images on the front panel.
The problem that iam having is that when i load an image onto the front panel it overwrites the other image. What i mean by that is , that instead of having two images on the front , each time i run the code it loads the same image twice onto the front panel.I tryed using a imaq dispose etc but it didnt work. Iam attaching a file that is similiar to the one that iam working on.
(incase i didnt explain it very well on my front panel when i run the vi i what to be able to load up two different images onto the front panel like below but try to load a second image it also replaces image 1.)
image 1
image 2
What actually happening
image 1
Thanks for help. Iam badly stuck.
(labview 7.1 and vision assisant.)
