displaying prime numbers in array indicator
hello there,
Can anyone tell me how do i display the prime numbers in an array indicator ?
My VI just tells only if the number is prime or not
Thank you
Akshay
(2,920 Views)
Hi akshay,
By putting your VI into a loop (to test more than just one number) and using autoindexing…
In a very Rube-Goldberg way…
Why do you divide by 1?
Why do you divide by every number, starting from 2? (Example: you don't need to test for "4" when you already tested for "2"…)
Why do you divide just 10 times (for divisors upto 10)?
Why don't you use the iteration condition in the FOR loop once you know the number is no prime?
(2,914 Views)
https://forums.ni.com/t5/Example-Program-Drafts/Prime-number-Array-of-quot-n-quot-elements/ta-p/3669...
Check this Link, u can get some idea regarding getting Prime number
(2,879 Views)
