distinguishing between controls and indicators
Hello to all,
In 6i it is possible to get a list of "controls" associated with a
particular front panel via a vi "property" however this list seems to return
the controls and indicators in the same list. I need some help figuring out
how to distinguish the "controls" from the "indicators".
Also, it would be great if it were possible to indicate which objects are
linked to a typedef.... i.e. a list of "controls" that are linked to
typedef xxx.
all suggestions greatly appreciated,
-- Bill --
(2,616 Views)
In the simplest way you can add
a descriptor for each control like " Control Value 1"
and after that paint the word Control as the same color as front panel.
Mike
william doggett wrote:
> Hello to all,
> typedef xxx.
-- Bill --
(2,616 Views)
