distribute VI with supported directory
I want to know if Labview can generate a intallation application with supported directory. For example, I have \Resource and \Report in my development folder. Then I use application builder to build a stand-alone application. When I install the application to c:\Program file, I hope the installer application could also create \Resource and \Report at the same time. How can I do it? Thanks!
Message 1 of 8
(3,509 Views)
Yes you can do that. What is your LabVIEW version? (Around 8.0, the application builder changed significantly.)
Message 2 of 8
(3,503 Views)
My Labview version is 7.1. Does it support?
Message 3 of 8
(3,494 Views)
I have not tested it, but in the app builder tab "Source Files" there is a button called "Custom destinations".
After this button is pressed a new window will appear an allow you to change the destination directories for every file.
I can't say how the installer will handle these paths, you would have to try.
André (CLA, CLED)
Message 4 of 8
(3,478 Views)
Thanks! I tried it but this setting can only set up the installation file folder. After I install the application, all the files will go to \data this folder which is not I want.
Message 5 of 8
(3,458 Views)
Admittedly, it's been awhile since I've built an application in LabVIEW 7.1. But to my knowledge, I believe you can specify Custom Destinations for specific source files in the Build Destination Settings Dialog Box.
From the LabVIEW Help:
Click the Custom Destinations button on the Source Files tab of the Build Application or Shared Library (DLL) dialog box to display this dialog box.
Use this dialog box to configure the build destination settings for a stand-alone application or shared library.
This dialog box includes the following components:
  • Files in build—Lists files included in the build of the application or shared library.
  • Source file path—Shows the path to the file you select in the listbox.
  • Build destination—Lists the default build directory for the selected file. To change the location, enter in a path or use the Browse button to navigate to the new build destination.
Let me know if I've misunderstood what you are looking for.
Cheers,
Emilie K | Applications Engineer | National Instruments
Message 6 of 8
(3,452 Views)
I know it is possible because I did this it myself. I created a "samples" folder that contain sample data files for the program tutorial.
Sorry, I can not you the exact steps because I no longer have access to LabVIEW 7.1.
Message 7 of 8
(3,448 Views)
Thanks! I found the way to set up it. It should be in Installer setting tab, and click files... button to set up all the locations. Thanks for your help!
Message 8 of 8
(3,442 Views)
