divide internal counter
I searched over forum but either no one asked similar question or it is well hidden.
The Problem:
I'm use counter output to generate pulse for stepper motor let say about 500Hz in cont. mode.
Every 10th pulse I have to measure something so I have to sunc. the sample clock od AI with counter, but the clocks are not the same.
I found an example how to divide external clock but there is no  how to use divide internal clock for AI sample clock.
The atatched example does not work properly  since when  I reduce the samples for AI, it also reduce pulse for stepper.
I use LV8, NI USB 6211 daqmx
Thanks for attention.
Any help is welcome.
(2,592 Views)
This is duplicate post:
(2,568 Views)
