dividing the hex to 8bit
how do i change this vi. so that after i received a continuous hex data it will divide into 8bit each
Message 1 of 8
(4,254 Views)
Use String to Byte Array or Typecast to a U8 array.
Your VI is not capable of a continuous read unless you use the run continuous button which you should NOT be using. Use a while loop and exclude the init and close from the loop.
Message 2 of 8
(4,242 Views)
is this one correct?
btw why i cant use the run continuous button?
if so how do i received continuous data from another program?
Message 3 of 8
(4,232 Views)
Is what correct?
Run continuous is for special debug uses and its silly to configure the serial port over and over again.
You receive continuous data by using a while loop around your read code as I already said. You really need to look at the LabVIEW 101 tutorial.
Message 4 of 8
(4,230 Views)
oh sory..i didnt notice that..here my vi.
Message 5 of 8
(4,226 Views)
I'm confused about what you actually want. If you get 'abc', you want a string arrray with 'a' as the first element, 'b' as the seond, etc? If so, why don't you just read 1 byte at a time with the Build Array function?
Message 6 of 8
(4,224 Views)
i want to divide it into 8bit
for example i received 123456788765432112345678.......
then i want to make array so my 1st element will be 12345678 and 2nd will be 87654321 and so on
Message 7 of 8
(4,219 Views)
12345678 is not 8 bits. If ASCII, that is 8 bytes. Which can be simply done by specifying 8 bytes to read.
Message 8 of 8
(4,210 Views)
