dll function prototypes seem to be lost
Hello all,
I´ve created a .LV (version 8.6) dll with some functions. Before building, I have created a prototype of the functions with all necessary parameters.
But....
If I call a function from this .dll, the parameters, which has been defined, seem to be lost. I see only a naked function without any parameter (void). I can define them in the config of "call library function", but where are my prototypes???
(2,510 Views)
Hi Mitulatbati
it seems to me that your issue his discusse din the following KB:
When I Create a DLL, No Parameters Show Up In The Define VI Prototype Dialog Box
http://digital.ni.com/public.nsf/allkb/BADA7A6A6C18AF2686256935005AF91E?OpenDocument
Pls ensure that the connector pane of the VI is corrected defined before you create the DLL.
Best regards.
Andrea P.
(2,481 Views)
