dll labview
Best question to ask is how do I build a parameter from the using the the call function library node in LabVIEW 8.6:  function prototype is the following as defined in the H file:
C1218 API  int __stdcall OpenSerialPort(char *comPort, errorStruct & err);
in the H file errorStruct is defined as follows
typedef struct
  int code;
  char   * msg;
  int msgMaxLenth;
} errorStruct;
this DLL does wrong with test stand, but not using Test Stand, only LabVIEW.
(3,140 Views)
Accepted by topic author hallawt2004
Duplicate post. Continue here.
Try to stick to a single thread. Please wait patiently for sometime. Somebody will surely help you to solve your problem.
(3,123 Views)
sorry for the duplicate entry, found a solution  parameter would be name:  err, type:  Adapt to Type  Data format:  Pointers to Handle
(3,080 Views)
