dll or API audio for windows
I have a sound file (4 tracks to have quadriphonic sound), when I play this sound with VLC, I don't have any problem but when I try to play with LabVIEW I have only the sound on the first and second but not on the tree and the four speaker. Do you know if I can communicate with API Windows 7 (dll for example) to play my sound file with my hardware which is TASCAM (US-16x08) thanks for your answers.
Best regards
(3,697 Views)
You should be able to use VLC itself, you just need to interface with it from LabVIEW. Here are some example codes (disclaimer: I don't know anything about those codes, I just found them now and they look like something you need): https://forums.ni.com/t5/Example-Program-Drafts/VLC-scripting-in-LabVIEW/ta-p/3515450
(3,691 Views)
Hi PiDi,
Thanks for your quickly link, i'll read this topic and i'll try it. But I wonder why we can not read a sound (Format 5.1; 7.1, quadriphonic etc...) directly in LabVIEW, probably we don't have the drivers audio to do this.
(3,688 Views)
Well, the Sound pallete in LabVIEW calls lvsound2.dll and it's hard to say what happens inside of it. I don't know if it was ever designed to do anything else than simple mono and stereo playback, so your best way to do something advanced is external lib/soft like VLC.
You could also try to check your sound configuration in the system and see if it's configured for multiple channels (speaker properties, like this: https://www.windowscentral.com/how-manage-sound-settings-windows-10-april-2018-update ).
(3,671 Views)
Yes of course I have already chek my sound configuration (Windows 7, just a little change between Windows 10) if not I can't play de the sound with VLC. In your previous link, I think, it's show how to read a video with VLC dll but in my case is to read a audio file with VLC dll.
Thanks for your helps
(3,667 Views)
