dll timing in development environment
I have a VI that uses a dll to communicate with a USB HID device.  I created it several years ago so I don't recall if I had this problem, but I suspeact that I did not.  Between the send packet and receive packet calls there is a 20ms wait.  Now when I am in the development environment I have to increase the wait to 210ms or I get no data from the receive packet.  Using a USB monitor program I can see that the PC receives the up packet from the device 63ms after the down packet is sent.  The receive packet has a 5000ms timeout.  If I build an exe with the 20ms wait, it works fine.  It must have worked before in the dev mode or I never would have tried to build an exe with it.  I am confused.  The original work was probably done in LV2011, but I no longer have access to that computer to test it.
Jim
LV 2020
(3,652 Views)
Has anything changed for USB HID? Did the instrument change physically or update the DLL that you are using?
(3,579 Views)
Hi Roxana,
No, this is the same dll and HID I got ~4 years ago.  The only thing that has changed as far as I know is that I have saved the VI for LV2013.  Unfortunately I was not smart enough to archive it before that.
Jim
LV 2020
(3,558 Views)
