dll
Hi!
     I want to build Labview application to dll.but I found I can't change the select opinion of changing "Function Prototype".
     For a simple test,I only programme "a+b=c" with labview.when I build it to dll,the Function Prototype is "void Add(void)".It doesn't allow me to change it.why this happen?How can I correct it?
    Another question is  if the problem above is solved,may it make a dll of labview application to contain another dll such as daq dll?
     Thank you !!
Message 1 of 1
(2,785 Views)
