dlls and Labview execuatbles
Dear All,
I regularly build Labview 8 applications which use dlls. However
whenever I build an installer, it doesn't copy across all the dlls
that my executable needs. In the short term, I can get around this
problem, by copying the files across manually, but is there any
setting I can change in the Labview installer to force it to copy
across all the dlls or other external file dependencies that I want?
Thanks in advance for your help,
Alan
(2,737 Views)
You should be able to manually add these files to your project and then include them as "Always Included" files in your build. By default these files will be copied to the "Support Directory". If that is not appropriate for your situation, you can configure the "Support Directory" to a different location or configure a separate destination.
If you are using a LabVIEW before 8.0, the exact options are different but the same sort of thing works.
(2,700 Views)
