dma transfer between host & target
(4,962 Views)
Can you also give a breif description?
(4,959 Views)
Oh I was typing my query in a notepad & forgot to paste it. Sorry!
So here i am trying to pass two data streams from host to target FPGA through FIFOs. I want to process these data streams on FPGA & write the output in another FIFO & give it back to the host. I have made a simple model for it. Forgive my ignorance but i dont understand the behaviour of the program when i set Count ( Loop Timer) to a low value like 20 ticks. What is actually happening when i want the FPGA VI loop to run faster? What I can i do to make sure that no output data is lost? Secondly are there any other constraints while using multiple FIFOs?
I am using PXI-7842R & LabVIEW 8.6.1
(4,936 Views)
(4,915 Views)
No! Smiley Indifferent
Message Edited by Alann on 10-09-2009 02:25 AM
(4,846 Views)
(4,810 Views)
Have you seen the Host synchronization examples for cRIO? You could implement triggers to ensure that the host and FPGA FIFOs are timed properly.
THanks,
(4,789 Views)
