do all the sub VIs in a reentrant VI need to be reentrant?
Message 11 of 14
(1,573 Views)
Please post a zip or llb of a demo that demonstrates your calls and I will comment.
This get to hard to talk through.
Ben
Message 12 of 14
(1,089 Views)
Hi Marce,
Essentially to determine if you want to make the subVIs reentrant, you want to determine if they are thread-safe:
  1. Does not have global storage data (global variables, files in disk, etc) or protect any global storage with semaphores/mutexes
  2. Does not access hardware (registers)
  3. Does not call functions/shared libraries/drivers that are not reentrant or thread-safe
The link in my previous post was to clarify the fact that if you do have information that is stored in the subVI, setting the execution to non-reentrant will cause problems with data being overwritten incorrectly. By making the subVIs reentrant, each subVI will have its own dataspace and will be a separate instance from the calling VI’s point of view.
Lemme know if you have other questions.
Kileen
Message 13 of 14
(1,058 Views)
Hello everybody,
Let me go back to the Reentrant issue.
I have a SubVi that should be reentrant in the final EXE application but I don't want it to be reentrant when I debug the program. I use a Boolean called SIMULATION to set several properties of my Vis differently when I debug and tried to use it also to set the reentrant property of the SubVi. Then I found out that LV won't let me change that property because the SubVi is already in memory.
Does anybody have any suggestion how to change the reentrant property in my case?
Marce
Message 14 of 14
(1,031 Views)
