Hi Mike,
If I understand your question right, you are trying to set the x-axis of the Graph programmatically.
You should use Property Nodes for this purpose. Right-click on the Graph that you want to change and choose "Create > Property Node". On the Property Node, use the 'Operate' tool (the finger) and choose "X-scale > Range > All elements". By right clicking, choose to "Change to Write". Do the same for the graph that you want to copy the x-axis from, but choose to read instead. Then wire the two Property Nodes together, and when running, you will see the x-axis being updated (see te attached example).
Philip C.
- Philip Courtois, Thinkbot Solutions
