do some calculation after reading the file txt
Hi, to all the pepole here that make a fantastic work thanks.
i never see a form like that, i'm new to labview so i have a lot of trable to do
a simple statistic report.
after i read out the data from the txt file i need to do some calculation. i dont know how to get the number out peer test.
alsow i neet to read out result and make an avrege peer test. need to read alsow the unit,lower,upper and display that .
after that i need to save all the result peer test and display them (if i press buttun) from the min to max.
 I hope that  u can help me with that.
i attached all the file.
Note that the TXT FILE CIH_BX.TXT MUST BE PLACED IN C: DRIVE.
regrads
eyal.
Message Edited by Support on 09-15-2005 10:52 AM
Message 1 of 1
(2,305 Views)
