03-20-2007 02:24 AM
03-20-2007 03:10 AM
Hi Sharmash!
Unfortunately you can't open a 8.0 application in 7.1. What you can do is use "save for previous version". You can only save for the most recent previous version, but I believe this would be 7.1 if you're using 8.0 (might be wrong there). Otherwise you need the version inbetween installed as well and repeat this operation within that version.
Martin
