do you have a lego driver
is there someone who has a example (in labview)for how to make a program for lego mindstorms RCX2
rob kroes
kroes@home.nl
(2,723 Views)
Hi Rob,
The LEGO Mindstorms software that you buy in toy stores will install an Active-X component called spirit.ocx which you can then use in LabVIEW. LEGO released an SDK with documentation on how to use this Active-X component:
http://www.legomindstorms.com/sdk/
Erik van Hilten
(2,723 Views)
Erik,
thanks for the answer.
I´ve tryed and see the result
rob kroes
kroes@home.nl
(2,723 Views)
