document of Labview optimization
I had seen the document (in pdf type) about the optimizaiton (memory and speed) in LabView programming.
I remembered the document had a NI part number.
Would you please let me know how to search it on http://ni.com?
(4,743 Views)
Are you referring to page four of the LabVIEW Bookshelf PDF (Help>>Search the LabVIEW Bookshelf...)?  There is a link to the application note "LabVIEW Performance and Memory Management", which gives several ways to improve LabVIEW code.
R
(4,731 Views)
Yes, I remembered the bookself menu in the earlier version of 8.2.1.
In 8.2, I can't find any link to the bookshelf.
Does anyone know about this?
Anyway, any more documentations, which I have to read, to optimize the LV code like this?
메시지가 08-03-2008 09:18 PM에 labmaster에 의해 편집되었음
(4,728 Views)
I don't think you'll find that document (app note 168) any more, probably because NI didn't want to have to update it.
I'm attaching it here, but you should note that it's not a magic cure and that not everything in it is even necessarily correct any more.
___________________
Try to take over the world!
(4,696 Views)
You may want to take a look at my Tag "LabVIEW_Performance" (and the related tags)where I have collected links to threads on this subject.
Ben
Message Edited by Ben on 08-04-2008 05:48 AM
(4,675 Views)
Hi Labmaster,
Here are two additional resources for you.
Optimizing LabVIEW Applications
LabVIEW 8.5 Help >> Fundamentals >> Managing Performance and Memory
I hope this helps.
(4,642 Views)
