does anyone have a base 64 encoder/decoder in LV 8.5 or older version?
Doc 5544 has one but it is in LV 8.6. does anyine have in in 8.5 or earlier??
your help is apprciated
(2,594 Views)
Accepted by topic author malyounes
I assume you're referring to the VIs in this Community Document: http://decibel.ni.com/content/docs/DOC-5544.
If so, you just need to ask someone here to backsave the VIs so you can open them in 8.5.
Like I just did... Smiley Wink
Note: I did not look at the VIs in detail, so I can't speak to their efficiency/accuracy.
(2,586 Views)
