does labview have driver to get readings from instron 4301
i'm new in using labview,can anyone out there tell me if labview has drivers that communicate with an instron #4301 instrument.And does Labview allow for database connectivity from the readings it might get from the instrument to be stored in a database.
Many Thanks to People replying !!
Thanx
(3,356 Views)
GIJ,
I'll assume that you've already tried Instron itself and been turned away by either price or availability. I would imagine that either they or one of a number of NI Alliance Members would be happy to sell you some software.
Assuming the 4301 is fairly old, then you might want to search the Info-LabVIEW Archives to see if anyone there can help. I took a quick look (searched for "Instron") and turned up a bunch of hits, many of which had e-mail addresses you could try. Of course, you can always try to program it yourself if you've got a reference manual for the instrument.
As far as database connectivity goes, you can purchase the add-on toolkit from NI, which works great, or you can dig around on these forums for something called LabSQL, which I haven't tried. There are other potential solutions too, and some searching and reading on this site should help clarify the options.
John
(3,350 Views)
You were right,most of them wanted to sell me the drivers at ridiculous cost.
thanx alot for the help john i`m going through most of the sites.
GI_Joe signing off...
(3,340 Views)
