dos
why when i run the command dos in labview with "System exec.vi" appears error messagge : "LabVIEW: Memory is full."
thank
(3,208 Views)
In this case, the error description, listed under Possible Reason(s), is misleading. The real error is that the command "dos" was not found. Under Windows 95/98 or 2000, there is no command named "dos".
What do you want to do? Run a DOS command (like DIR or TYPE, etc.) or just open a DOS command prompt window?
Depending on what version of Windows you're running, to open a DOS command prompt window, use one of the following command lines with System exec.vi:
COMMAND.COM
or
CMD.EXE
and have wait until completion False.
If you want to run an internal DOS command like DIR, use one of the following command lines:
COMMAND.COM /C DIR
or
CMD.EXE /C DIR
If you set wait until completion True, the output from DIR will go to System exec.vi's string indicator labeled st
andard output.
(3,208 Views)
Does this link help?
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/ea1600eba422e97286256aa20073c616?OpenDocument
2006 Ultimate LabVIEW G-eek.
(3,208 Views)
