dot net dll and touch panel module
Hi all,
Is there any possibility to use a dot net dll with the touch panel module on LabView 2011?
Thanks in advance...
(2,965 Views)
Hi Oimel
I think the limitation of this is not LabVIEW.
When .net running on your Touchpanel OS thus it should works with LabVIEW and the touch panel modul.
best regards
(2,948 Views)
This appears to be related to this:http://forums.ni.com/t5/LabVIEW/call-dll-function-on-Windows-CE6-0-Device/m-p/2092170
Since you already know that the device would be running Windows CE or Windows Embedded Standard, the question is really can Windws CE or Windows Embedded Standard use .NET? Not sure why you are asking this on a National Instruments forum, since it's a Windows question. I do know that .NET compact is available. Have no idea how well it works.
(2,941 Views)
I'm talking about two different libraries. The one from the other post is a C library.
The one I'm talking in this post is a net compact framework 3.5 library (to be precise). It will work on Windows CE6.0.
I'm asking this on a NI forum because I wanted to know if there is a possibility that LabView can handle this dll in a touch panel project.
(2,937 Views)
