Version 1) Initially develope a LabView 8.2 Dot Net Program that uses a private DLL to access propriatary hardware .
Version 2) The Software developer updates the private DLL and I apply the updates as necessary to my LabView 8.2 Developement machine.
When updating from Version 1 to Version 2 above the LabView apps are broken.
I repair the apps as necessary.
I test the apps -- they run without error.
I save the apps -- they save ok
I reopen one of the apps and it shows that there are unsaved changes ( It says the vi was recompiled).
I have to manually replace many dot net objects and reconstruct them with new objects of same type.
Save ok.
Reopen ok
I believe that each LabView Dot Net application is caching information about the previous DLL used. Is there an easy document available that describes how to update dll references globally?
