doubts in lin
Master has sent a header for which two nodes have responded simultaneously. So there is a collision. Now master resolves this by giving priority to one of the nodes by sending unconditional frames individually to the nodes.
Doubt is when there a collision how slaves stop behave? As per slave state machine there is a read back and so one of the node should pull back the transmission. Then what about the other node which has succeeded in transmission?
 If error is handled in a master how this works… how above error is handled?
How synchronization works?
How slave decides the identifier after getting synchronized with master? Mainly how without a clock only with Tbit period that it has got from sync?
please let me know your view.
cheers
ganesha
(2,802 Views)
Hi, Ganesha.
Check out my post here.
Sarah K.
Search PME
(2,773 Views)
