downloading bit file to USRP X310 using labView 2018
i am trying to load a bit file of an example named( USRP streaming) complied using LabView for 2018 but i  am getting hardware failure error 63150. My target hardware is USRP X310 . I have connected it to my PC through PCI cable . can anybody elaborate why i am getting this error is it due to a missing software utility or some other . Either if someone can refer me a simpler example to step by step guide to create and load a customize project to USRP X310 FPGA
(1,182 Views)
I have the same problem. USRP 2954R(X310) labview2024Q1.
(478 Views)
I solved the problem by first connecting PC and USRP, starting USRP then starting the PC.
It turned out that there was no more error -63150.
It seems the order to start the device is pretty important.
(462 Views)
