drag and drop not working 2012 and Win 7
LV 2012 Pro V1.0.1f3. No special font settings. I went into my options to make sure.
PaulG.
Retired
Message 11 of 42
(1,611 Views)
Are both LV and Windows 64-bits?
@Paul: The version number you refer to is SP1, isn't it?
Norbert
Norbert
Expert: Geometry
Message 12 of 42
(1,602 Views)
no only win7 is 64 bit, LV is 32 bit (Full development System Version 12.0.1f3)
Regards Florian
Message 13 of 42
(1,597 Views)
Ok, just for clarification: By dragging a path, you refer to dragging the path from a Windows File Explorer window to the LV Block Diagram window just like this:
I tested my LV 2012 (no SP) 32-bit with Win 7 64-bit and it doesnt drop anything. So i would say that i see the behavior you describe. Correct?
Norbert
Norbert
Expert: Geometry
Message 14 of 42
(1,591 Views)
Correct,
though it bugs me more that the snippets don't drop as intended.
Regards Florian
Message 15 of 42
(1,585 Views)
Yes, SP1. Windows and LV are both 32-bit
PaulG.
Retired
Message 16 of 42
(1,581 Views)
From Windows explorer I used to be able to drag a file or folder into a path constant on a block diagram and that file or folder path would drop into the constant. Same thing with snippets. Now I can't. I get a "not" - looking cursor and nothing happens.
As a work-around I can right-click and browse to the file or path (a real pain) but snippets still don't work.
Windows drag-and-drop between windows works fine.
PaulG.
Retired
Message 17 of 42
(1,578 Views)
@PaulG. wrote:
From Windows explorer I used to be able to drag a file or folder into a path constant on a block diagram and that file or folder path would drop into the constant. [...]
OK, using LV 2012 32 bit without SP running on Win7 64bit, i cannot reproduce this. I will try to get my hands on a machine with SP1 on hopefully both Win7 (32/64bit) and try it there. It really sounds like a bug, but without reproducing it, i will not further comment this 😉
Norbert
Norbert
Expert: Geometry
Message 18 of 42
(1,567 Views)
I it working for me.
Windows 7 Enterprice SP1 64 bit
LabVIEW Dev. Suite 2012 SP1 1.01f3 32 bit.
I can drag and drop a file from windows explorer to a path constant on the block diagram and get the path to that file.
I can also drag and drop a snippet to the block diagram to get the code.
Message 19 of 42
(1,562 Views)
PaulG. and I both have LV 2011 SP1 installed besides LV 2012.
Could this contribute to the issue?
Regards Florian
Message 20 of 42
(1,559 Views)
