drag drop capabilites lost when compiling
Hi all,
Platform : LV8
OS : XP-pro
In one VI I have 2 trees, named "Actions" and "Programmed script" (see attached picture).
The "Actions" one is used as a choice list from which I drag only.
The "Programmed script" one is drag and drop so you can insert items taken from "actions" and move them around.
When I use my code in source mode the behavior is as I programmed it to be.
When I compile it, I cannot drag and drop anymore. Has any one any Clue ?
Thanks.
Cheers,
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(2,837 Views)
It's a bug, as seen for example in this buglist.
___________________
Try to take over the world!
(2,828 Views)
Thank you TST.
I spent allready a couple of hours compiling and testing ... I am sure you know what I mean !
Cheers,
Doc-Doc
(2,820 Views)
