drag simultaneously multiple waveform chart scroll bar
I have multiple signal that come from the same source and I want to plot on separated waveform charts as on the example that i attached, So far all good, but I would like to be able to use a single scroll bar to scroll all the charts simultaneously in order to compare the values, I have been searching the forums but cant find the way of doing it. Any  suggestions? thanks
(3,529 Views)
Accepted by topic author vinagres
This does the job I think.
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
(3,514 Views)
The information on the other graphs are a bit flickery, not so smooth as is on the waveform chart that controls the others, but for what i need it more than enough, Thanks
(3,507 Views)
Try wiring the X Scale.Range.Start property as well and see if that helps.
Kelly Bersch
(3,502 Views)
