dragging attachments
How can I drag and drop labview attachments from the forum to labview block diagram page? It is not allowing me to do it. I am using labview 2011.
Thank you.
(2,536 Views)
The problem is most likely with your browser - most browsers don't allow dragging images to another window. You can either save the file and then drag it into LV or you could use this - https://decibel.ni.com/content/docs/DOC-6229
___________________
Try to take over the world!
(2,528 Views)
