draw a straight line
Design a system that can plot a straight line from the coordinates of two given points
using for loop and formula from block diagram
can someone help
(1,680 Views)
My guess that this is homework, why else would there be such specific requirements (FOR loop, formula, etc.). You don't really need any of that but it's a good learning experience.
  • Start with the training resources listed at the top of the forum.
  • Look at your class notes
  • talk to your classmates
How far did you get so far?
  • Did you figure out how to create a new VI? (it's not a "system!)
  • Did you find the front panel and block diagram?
  • Did you find the FOR loop?
  • Did you find a way to enter the coordinates on the front panel?
  • For arbitrary lines, use an xy graph. did you find that? Did you read the help for it?
  • Given two points, a plot of the xy graph can draw a line between them. No extra code needed.
  • Personally, I would use plain graphical code, no formula node
  • etc.
(1,662 Views)
The length component of the problem was solved a few millennia ago by a guy named Pythagoras.
It sounds like you have a point A to start at  and a point B to end at already.  All you need then is to figure out which way to go and how far to go that way.
That sounds like a nice continuation of the Greek theme!  Maybe you could find some Math Functions that have parameters of Rho and Theta 😉
I cannot understand why you would need a loop and all the functions needed are easily available.
(1,618 Views)
I did not see any "length" component in the problem description, but the term "plot" could of course mean many things. For simplicity, I assumed a virtual line on an xy graph, but it could easily also be about how to drive two stepper motors of an xy stage moving a real pen around. 😄
(1,614 Views)
Oh, in that case we only need M and B!  Double check me but, isn't get scale (linear) on the Math pallet still?  I thought that accepted an array of points as cluster <x,y>
(1,603 Views)
We still don't know what a "system" is (as in "... design a system ...").
All we probably need is a size=2 complex 1D array defining the two points, a wire, and a xy graph. 🙂
(1,597 Views)
