draw multi curves from spreadsheet files
I want to show many curves on one XY graph. Each curve was stored in a spreadsheet file. Please helpme.
Message 1 of 9
(3,914 Views)
Accepted by topic author hanh
Message 2 of 9
(3,908 Views)
Message 3 of 9
(3,890 Views)
Thank you so much. My problem was solved
Message 4 of 9
(3,888 Views)
So, can you mark the reply that solved your problem as the solution?
- Partha ( CLD until Oct 2027 🙂 )
Message 5 of 9
(3,878 Views)
 My probelm was solved thanks to an example given by Mathan. This example ( xygraph.vi) was from Nirmal Sharma. I don't  know how to reply. However,thanks for the very quick response.
Message 6 of 9
(3,859 Views)
Then please mark Mathan's post as solution to your problem. You can do this by selecting "Mark as solution" from the options menu located at the top right corner of Mathan's post.
Mathan
Message 7 of 9
(3,852 Views)
Thank again for your guidance. Now I know how to remark the aceptable solution. Great work.
Message 8 of 9
(3,844 Views)
You are here in this forum for almost 6 years and i expected that you know the new features in the forum like marking solution and kudos.
Anyway glad to see your problem is solved. Don't hesitate to ask any kind of help. People will serve you better.
Enjoy wiring.
Mathan
Message 9 of 9
(3,841 Views)
