drawing a mesh on a 3D graph
I want to draw a mesh on a 3d graph.
As seen in attachment, the mesh can be presented on graph using 3D surface control.
But, I don't know why the z value is presented differently according to the x vector.
X_Sine mesh on Sine wave vs. X_Linear mesh on Sine wave.
Is this right?
I want to present sine mesh on sine 3D surface.
Is there a suitable way for this?
(I want to give the concept of 2d interpolation according to mesh representation.)
labmaster.
Message Edited by labmaster on 12-01-2009 12:49 PM
(3,361 Views)
The linearization could be understood under sine vector in X.
I want to modify my question... How to represent the sine mesh on sine waveform with a labview control?
labmaster.
(3,351 Views)
Your posted code shows a mesh over both plots.
I do not understand what it is you don't like or want to change.
Lacking that info I can't think of anything else to say.
Ben
(3,345 Views)
Thanks.
How to add the sine mesh (left hand drawing) on the sine waveform (right hand drawing)?
labmaster.
(3,338 Views)
OK thanks you!
in this thread I posted a worse case 3d graph example that uses multiple plots in the same graph using
the "add" method for each plot. Please review that thread because I explained everything that I did and I posted full code so you "can roll your own".
Have fun!
Ben
(3,329 Views)
