drawing vertical lines
Hi, I am outputting data from a spectrometer onto a graph and wanted to add some vertical lines in the background to designate the peaks I am looking for. I was able to to use the "plot images: back" property node and "map xy to coordinates" but how do I draw lines not starting from the origin? Any suggestions are appreciated.
(3,653 Views)
it depends on what graph you are using; for XY you can add something like (x1, y1), (x1, y2), (nan, nan), and so on,...the height of the line would be y2-y1
N
(3,645 Views)
Thanks for the reply. The problem is that I'm using a waveform graph and the input to the "draw line vi" is the endpoint. I'm not sure how to start the line anywhere other than the origin.
(3,627 Views)
Accepted by topic author bryantbeau
move pen
Ben
(3,624 Views)
