driver for Digidata 1200 from axon instruments?
Our setups are equipped with Digidata 1200 boards from axon. For an experiment I need to do some online analysis which requires Labview. Before we buy it, I must know whether I can connect the Labview to my Digidata board.
(5,953 Views)
Unless someone here has done it before, your best bet would be to contact Axon and see what the programming interface for their card is. Many manufacturers provide LabVIEW drivers since LabVIEW is so widely used. If they provide a DLL or ActiveX control, then it should be possible with a bit of your time and sufficient documentation from Axon. LabVIEW only comes with drivers for NI cards.
(5,954 Views)
> Digidata board.
I've got the same problem.
As I asked I recieved a zip-file from axon with the comment, that i
could use the data included, but except from the documentation inside
the zip-file that there's no support.
There was no documentation, but the comments in the Source-Code.
There are some vi's that cal CIN. But they all didn't work with LabView
6i (on WinNT 4) and i couldn't get it to work.
I then grabbed an old Box with Win95 and labwiev 4.1 for which i found
some working vi's and dll's. This is the setup I'm working with
now. It
works but isn't optimal.
If you need some more Informations or the file, I can send it to you.
If you've got some more success, please tell me!
bye
Marco
PS: for mailing me, remove the "nospam" part from my address
(5,954 Views)
Hi Marco,
I have Digidata 1322a a product of AXON and i need labview drivers. Do you know where i could find one...?
Do u think 1200 drivers wud work for this setup If so cud u plz mail me a copy of the drivers.
Srikanth
(5,954 Views)
Macro,
I was wondering if you still had the drivers for the digidata 1200 boards from axon?
If so I was hoping you could email them to me and any working vi's or dll's.
 Kevin
(4,814 Views)
