driver for Tek TDS 744 scope
I downloaded a driver from NI for this scope (TDS 744 Tektronix). After unzipped installed I tried to use and it is missing many sub vi's. Anyone have a version that works?
Thank You
(2,839 Views)
I just downloaded the 6.1 and 7.0 versions of tktds7xx.zip and found all of the VIs (at least all in TDTDS 7XX VI Tree). There are two llbs in the zip file. One in the tktds7xx folder and another in the _shared folder. If, when you try to open a VI and it asks for one, try pointing to the llb in the _shared folder.
(2,839 Views)
