driver for hp 54845A?
i'm searching for a gpib-driver for the oscilloscope hp 54845A. i'm using labview 5.0.1 and 6.i. can somebody help me
I already found a lv 6.1-driver for the hp 54845A. Can I use it in lv 6.i, too? More importantly for me would be a driver for lv 5.0.1, since my predecessor already developed some programs with this version and so my boss would like to change the version only reluctantly.
(2,629 Views)
Thank you for contacting National Instruments. Unfortunately, the only versions of the driver available for use are with versions LV 6.1 and LV 7.0. You cannot use the LV 6.1 version with LV 6i; the minimum application development environment requirement for the driver is LV 6.1. You could try to get around this issue by saving the VIs from the LV 6.1 driver to a previous version; however, I cannot guarantee this will work because most likely the driver is using functionality available in LV 6.1 and greater.
(2,629 Views)
