driver from LLB file
Hi ALL
we have LLB file for device can we convert it to driver using from Function Palette>>Instrument I/O>>Instrument Drivers
Message 1 of 8
(5,984 Views)
Hi eng,
why don't you just use the VIs inside that LLB? No need to convert...
Message 2 of 8
(5,746 Views)
thank you for reply
i have 590CV.llb and using labview 11
who can i use it?
by insert it to project or what
can give me example
Message 3 of 8
(5,737 Views)
An LLB is just a collection of LabVIEW files into a single file.  Think of it as a zip file with a flat hierarchy.  Yes, just add it to your project and you will see all of the VIs inside of it.
Message 4 of 8
(5,726 Views)
i try to insert any vi from LLB but i can not do it
Message 5 of 8
(5,724 Views)
Accepted by topic author engmoh
Hi engmoh,
you can open any VI inside that LLB. And you can insert all those VIs as subVI of your own mainVI…
Hint:
  1. Create a new project.
  2. Drag that LLB from an explorer window into your project.
  3. You will get a new folder inside your project containing the content of the LLB…
Message 6 of 8
(5,715 Views)
An image is often pretty useless to help debugging a problem if it is more than the most basic obvious problems. Your llb could be saved in a version that your LabVIEW can not open anymore (to old), or not yet (saved in a later version).
It could also be that the VIs are saved without diagram (source code). The image doesn’t let us look at this!
Rolf Kalbermatter  My Blog
Message 7 of 8
(5,661 Views)
thank you very much
Message 8 of 8
(5,515 Views)
