driver instal
Hello!
the labview 8.5 instal in comp , that not have internet conection. I download driver from chroma site (elctronic load 6320X), now i don't know how to instal this driver. All exampales and help explains how to do this , if you have internet conection.
PLEASEEEEEE help......
P.S. The driver have two files, *.lib  and *.dll
Message 1 of 19
(5,017 Views)
Could you post the URL of the download location?
It just doesn't show up in Google.
André
André (CLA, CLED)
Message 2 of 19
(5,012 Views)
http://www.chromaate.com/english/driver/detail.asp?id=13
I need hlp to instal driver , i can't use search becouse labview first check my internet connection (
Message 3 of 19
(5,009 Views)
Could it be *.LLB and *.DLL instead?
  • The LLB file is a collection of VIs that you can place on your diagram.
  • The DLL is most likely used by these driver VIs for some of the lowlevel function. Most likely you just need to ensure that is it in a place where LabVIEW can find it.
Was there any readme file with the driver?
Message 4 of 19
(5,007 Views)
This is not a LabVIEW driver, but a labwindows driver.
Try this instead:
http://www.chromaate.com/english/driver/detail.asp?id=12
Message Edited by altenbach on 09-03-2007 12:12 AM
Message 5 of 19
(5,007 Views)
I just downloaded it.
It only has the DLL, the header file and a C example for use in CVI.
André
André (CLA, CLED)
Message 6 of 19
(5,001 Views)
I have labview driver , but no change in instalation (
no txt file
Message Edited by Vaj on 09-03-2007 02:19 AM
Message 7 of 19
(4,999 Views)
Message 8 of 19
(5,000 Views)
The driver contains a LLB file. It conatins all the necessary VI's.
You can add the LLB to your project to access the VI's.
Don't forget to :
- place the DLL in the same place as the LLB.
- install the required dependencies.
André
Message Edited by andre.buurman@carya on 09-03-2007 02:22 AM
Message Edited by andre.buurman@carya on 09-03-2007 02:24 AM
André (CLA, CLED)
Message 9 of 19
(4,996 Views)
Double-click the LLB file, and the toplevel VI named "chr6320x Getting Started.vi" will open in LabVIEW. The diagram is pretty ugly, but is shows how to call some of the driver VIs that are also included in the LLB.
Message 10 of 19
(4,981 Views)
