driver problem superlogics module 8000
Hi all,
I just got a driver from superlogics for modules 8000 who is suposed to work with LabVIEW 8.5.1 because the driver that you can get on their website is not working with LabVIEW 8.5.1.
The problem is I can't see the driver on the list "Instrument Drivers" in the block diagram.
Best regards
popo
(3,140 Views)
Hi Popo,
Where did you install the files from your driver installer?
In order to get a palette in the Instrument drivers palette, you should copy the folder in C:\Program Files\National Instruments\LabVIEW 8.5\instr.lib
Olivier L. | Certified LabVIEW Developer
(3,127 Views)
Hi Olivier,
Thanks, got it and it's working fine.
Best Regards
popo
(3,120 Views)
